Top Rated Dry Bulk Cargo Site
FrankJScott
Сообщение: #11025 FrankJScott
14 дек 2021, 02:02
The general purpose and functions of seagoing bulk carriers
There are numerous risks that can be encountered while operating seagoing bulk vessels. Careful planning and exercising due caution for all critical shipping-related issues is essential . This site is a quick reference to an international shipping community, offering guidance as well as information regarding the discharge and loading of different bulk cargo types . It is to stay within the limits according to the guidelines of the classification society. It is essential to minimize the chance of stressing too much on the ship's structure , and adhering to all safety measures for a safe sea voyage. The detail pages of bulk carriers are filled with information that may be helpful to those who work at the terminal and those who work aboard.
General features for bulk ships that travel by sea.
Bulk carriers could be single-deck vessels. They come with top-side tanks and side tanks that hoppers can use. These tanks are used in cargo spaces. They are built to transport bulk solid cargo. Solid bulk cargo can refer to any material, other then liquid or gasoline made up of a combination granules and particles. The materials can be loaded directly into the ship's cargo spaces with no sort of containment. These dry cargoes can include bulk grain, sugar and ores. The broadest definition of the word bulk carrier, any vessel built to carry bulk cargo (solid or liquid) in bulk would be classified as bulk carriers. Tankers are also included under this umbrella. However, in common usage bulk carriers are utilized to describe vessels that are designed to carry bulk solid cargos. This is a reference to grain and similar agricultural products along with minerals such as iron, coal ore, stone, and coal. Peruse this handysize bulker site for more.
What Is A Bulk Car The Main Characteristics Of Bulk Carriers Are:
"A ship which is intended primarily to carry dry cargo in bulk, including such types as ore carriers and combination carriers"
Carrying capacity ranges from 3,000 to 300,000 tonnes
Averaging speed between 12 and 15 knots
-Single deck ships, ie no tweendecks
Carriers of medium to small size bulk (carrying capacities between 40,000 and 60,000 tonnes) generally have cargo handling gear. However larger vessels may use facilities on shore to load or unload.
-Cargo hold dimensions are generally big with no obstructions. They also come with larger hatches that enable easy loading and unloading.
One cargo hold is usually designated as an ballast storage. This can be used on ballast voyages in order to increase stability. One or two further holds could be allowed for partially ballasting but only when in port.
They are equipped with single pull, hydraulic or stacking (piggy- back) type steel hatch covers
-Four types of ballast tanks :
Sloping topside wing tanks
Sloping bottom side of wing tank
Double bottom tanks
Peak and post peak water tank.
What is a solid bulk cargo? Any material, other than liquid or gas, consisting of a mix of granules, particles or any larger pieces of material generally of uniform composition and loaded straight into the cargo containers without any intermediary method of containment. It is imperative to make sure that all cargoes are ready to be loaded, regardless of whether they're "clean" or "dirty", and that there isn't any contamination. Surveyors are often required to inspect the space and determine if the space is suitable to be loaded. To prevent contamination from occurring it is crucial that any leftovers left by a previous cargo be taken away. The bulk cargo is the most vulnerable to water damage. This means that the storage areas must be dry in order for the cargo to be accepted. Additionally the hatch covers should be sealed and watertight if necessary to prevent water intrusion. All fittings inside the storage area (ladders pipes, ladders as well as bilge covers.) You should inspect every fitting in the hold (ladders,pipe guards, bilge covers...) to ensure that they're in good functioning order. If they are not properly fitted, these pieces of equipment may cause severe damages to conveyor systems which can lead to delays. Check out this voyage charter blog for more.
Bulk Carrier, Bulker? Bulk Carrier, Bulker A vessel that can carry dry cargo. It is not intended to function as a liquid bulk tanker or carrier. A traditional bulk carrier is equipped with one deck, a one skin, and a double bottom. It also has topside tanks, hopper side tanks and cargo space tanks. Bulk carriers are built to transport bulk cargo of any weight either light or heavy, and can carry a maximum weight of 450 lbs. The procedure of loading, transporting and the release of dry bulk cargo is more complicated than many people imagine.
Gearless Bulk Carrier
Many bulk cargoes are hazardous and may be damaged throughout the journey. Uncorrect loading can cause damage to the vessel easily. loading the forward hold to its maximum can cause the ship to be bent. This is known as stress? could have fatal consequences during rough seas. Other cargoes can also be affected by residuals from previous cargoes. Certain bulk cargoes are vulnerable to damage from water. cement power. It is difficult to verify the amount of cement used and the weight of cargoes unloaded and loaded. All of these factors have serious consequences for safe bulk cargo transportation. Discharging bulk cargo using? Bulk cargoes have the tendency of forming a cone when they are loaded when conveyor belts or similar systems aren't monitored and controlled. The angle that is created by the cone is referred to as 'angle of repose'. It is different from one cargo to the next. Iron ore, for instance, will form a steep angled cone, whereas cargoes that flow freely create an angled cone that is shallow. Cargoes that have low angles of repose tend to move more during transit. Bulldozers could be used for some cargoes in order to spread the load onto the sides of the holding because the cargo is close to being completed. The majority of dry bulk carriers rely on shoreside facilities for cargo loading and discharge however certain bulk carriers come with self-unloading features with conveyors below the cargo holds or with cranes mounted on deck.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 9 гостей
